Help me ID peice of metal I found in pumpkin
Old Feb 16, 2015 | 09:59 PM
lethaldomestics's Avatar
i found this in the pumpkin dif. of a rearend i bought some time ago.
The rear end is a disk break posi out of a 89 iroc. i was told the piece of metal is a clutch? All the teath on the gears are intact. Where can i buy this piece?
Any help identifying the rear end would be awesome also. Thank you very much
Old Feb 17, 2015 | 09:39 AM
big gear head's Avatar
Re: Help me ID peice of metal I found in pumpkin
The picture is out of focus, so it's hard to tell for sure. It looks like it might be part of a clutch disc from a Governor Lock differential. It could also be one of the differential shims.
If it's a piece of a clutch disc from a Governor Lock then don't bother trying to replace it. Just replace the whole differential. The Gov Lock is not a good differential for a performance car. They break a lot. Get a new Eaton Posi, Yukon Dura Grip or a Power Trax Grip Lok.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
rudolphschenker
Sep 4, 2015 02:41 AM
mrdevontay
Sep 2, 2015 08:04 PM
