4L60E tailshaft housing woes..
Car: 1984 z28
Engine: first gen small block 350
Axle/Gears: stock
alright so ive searched the forums for awhile now and cant seem to find the answer im looking for.
now im going to use the 4l60e that came with the motor out of a 2000 Silverado. So my problem is with the tailshaft housing. I need to still be able to bolt my torque arm up to it. ive seen some adaptors that make the 700r4 tail housing bolt up to it, but they are a little pricey. Can i get a tail housing off a 98-02 Camaro or firebird that had a 4l60e in it ? cause ive been searching and i cant seem to find anything and its getting really frustrating
and advice would be awesome!
Re: 4L60E tailshaft housing woes..
I don't think you can use just use any tail shaft housing from a 4L60E F-Body. You'll need to find a housing off of a 1999-2002 F-Body for it to bolt onto your 2000 4L60E.
GM changed the housing from a 4-bolt to a 6-bolt housing in 1999.
Car: 1984 z28
Axle/Gears: stock
Its always the little things holding up my projects.
