Opinions on brakes for Quick Performance 9" rear
Old Feb 26, 2015 | 09:28 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Hey guys, I'm looking at purchasing a Quick Performance 9" housing and axle package. I have a center section in the shed. (I'm not sure if it's nodular iron or cast) Where can I find a used 35 spline locker for a decent price. Also, what are you guys running for brakes? I want to keep my factory wheels.
Thanks you.
Old Feb 26, 2015 | 08:41 PM
big gear head's Avatar
Re: Opinions on brakes for Quick Performance 9" rear
You can't use a 35 spline differential in a stock Ford case. You must have an after market case with a 3.25 bearing bore to use a 35 spline differential.
Old Feb 26, 2015 | 08:52 PM
Night rider327's Avatar
Car: 1988 Camaro
I use second gen F body drum brakes on mine. Used the backing plates from a 1978 firebird parts car I had. Enlarged the center hole to fit the ford 9" housing ends. I used new wheel cylinders and brake shoes for the '78 firebird.
Old Feb 26, 2015 | 10:10 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I got the disc brakes that QP provided with it.
I believe they are from a G-body.
Old Feb 26, 2015 | 11:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
I fabricated brackets and installed rear disk brakes from a 99 Jimmy.
Sticky at the top of the brake forum. Disk brakes for any differential.
I still want to refabricate the brackets and install a second set of calipers.
As mentioned above, you won't be able to fit a 35 spline carrier into a stock housing.
Old Feb 27, 2015 | 03:26 PM
buckshot63's Avatar
Car: 93 Z28/ 92 Z28 Purple Haze conv
Engine: LT1/305TPI
Transmission: 6 Speed man/ 4 sp auto
Buckshot here. As long as you're interested in buying a mfg. rear, Trick Chassis in Beloit Wi. built mine. Alex there can help you out on the details, will custom build it, (I had 1/2 inch off each side for mine), get the correct axles, and put the ends on that you want. I had him use mounts for 4th Gen. for mine, and they bolted right up. ( Bought a set on ebay). These are Direct bolt ins, and Reasonable. I see you are in Wi. At least worth looking into. He makes a very nice piece. I am very happy with mine. Bill Nelson, 87 IROC 383 Stroker.
Old Mar 3, 2015 | 09:37 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Check online for some of the guys that deal with used stuff from like Hendricks motor sports and other nascar teams. they have ford 9 rear parts and lots of other parts that are top of the line and very cheap. I bought a locker that was out of either Jimmy Johnson or Jeff Gordon's car along with the yolk (it has the pulley on it for the rear cooler). This was way back when Hendricks was a two car team. I got some stuff from jo Gibbs racing as well.
Old Apr 7, 2020 | 07:09 PM
Nick Hain's Avatar
hey I just got my quick performance rear end and wanted to know how you fabricated your brackets... I got a 4th gen camaro rear disc brake kit and the brackets do not fit over their 4th gen axle flang... can u show me yours and how you ended up doing it?? Thanks!
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
novaderrik
Aug 10, 2015 12:44 PM
