cable too long
Old May 5, 2015 | 12:35 AM
sgp0511's Avatar
Car: 1988 Firebird
cable too long
Just swapped from TBI to carb and TV cable is too long will this work when wot cable is fully pulled
Old May 5, 2015 | 01:55 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: cable too long
Can't see in the pic what carburator you are running, but the linkage has to be set up correctly for the TV Cable to work properly; I believe most quadrajet carbs have the correct linkage, but Edelbrock and Holley carbs will need a special bracket to maintain the correct ratio between the throttle and Valve Body movement. And of course you must make sure you do an initial TV Cable adjustment, even with the correct linkage.
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
TheTraut88
Sep 11, 2015 05:16 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
