4th Gen rear
Old Jun 13, 2015 | 08:38 PM
Mikeroc283's Avatar
Car: 85 Camaro Berlinetta
4th Gen rear
Would the rear from a 4th gen fit and hook up to my car fine or would there be an issue with the brakes and how the driveshaft attaches?
Old Jun 14, 2015 | 07:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th Gen rear
The swap is common and requires nothing special. A quick search will provide you with a wealth of info.
Best of luck,
JamesC
Old Jun 15, 2015 | 12:09 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: 4th Gen rear
Pretty much a bolt in swap.
The 4th gen is wider and if you use your stock wheels they will stock out almost 2" per side... Or you can use 4th gen wheels and get them back under the wheel well.
If your car is rear drum brakes now, and the 4th gen is disk rears you will need a disk/disk prop valve
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
