Broken flex plate
Car: 1989 Camaro RS
Engine: LO3
Broken flex plate
Hey guys. So i definitely cracked/destroyed my flex plate. But im not sure if more damaged was caused.
Since i bought the car the transmission has shifted pretty hard. It has 112k on it, paired with an lo3 305 tbi. Today i floored it and suddenly it bogged down and i started hearing a clicking. Clicking i now know is the flex plate considering i cant even start the car anymore. The starter just spins and you can hear a light grinding.
However while it was running it also wouldnt down shift. I could completely floor it and it would just hang at 2000 rpms and VERY slowly accelerate. When giving it any amount of throttle would not down shift like its supposed to under load. Not sure howq else to explain it accept that the car accelerated really slowly, like it had 50hp.
Is this a seperate issue or could the broken flex plate cause this?
Re: Broken flex plate
Prolly 2 separate issues; can't imagine how anything about a flex plate could conceivably cause a low-power problem like that.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i had the center tear out of the flexplate in a 92 Caprice 9C1 that i used to have: the whole center broker out about 1/4" outside of the bolts that held it to the crank.. it drove fine, but made a ticking noise. i still have that flexplate somewhere because i thought it was cool the way it broke..
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Yup; gotta be the most common way for em to fail. We'll probably never know how many cars have been scrapped for making that noise.
Car: 1989 Camaro RS
Engine: LO3
Yeah. I knew it wasnt a knock in the motor based mostly on the particular sound it made. It was a very random tapping, not a rythmic tap like a motor would make.
That and my Transmission started fudging up and the starter just spins.
no green
Jan 9, 2016 09:22 PM
monte87cortez
Sep 26, 2015 08:10 PM
