View Poll Results: What Gears would you put in a car that you wanted to use still as a Daily Driver?
3:42
75.00%
3:73
16.67%
Other
8.33%
Voters: 12. You may not vote on this poll
Rear RPO Codes....again please
Old Dec 18, 2001 | 12:27 PM
PopaPork's Avatar
Hey guys I know I just asked this but when the boards went down my link that that I saved for this post before went bye bye too. So any way. Any one know the RPO codes for a 3:42 and 3:73 Rear and The RPO code for the Posi unit? Also if the RPO codes are gone from the donor car is there another way to figure out whut the gear ratio is, besides pulling the cover plate off and counting the teef? Thanks alot.......again
Old Dec 19, 2001 | 08:08 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
GU6 is for 3.42's, and GT4 is for 3.73's. Posi is G80. One way to figure out the ratio is to disconnect the driveshaft, then spin the wheels. Count how many times the yoke (on the differential, where the driveshaft was) turns when you turn the wheels once. If it turns about 3 and a half times, thats a 3.42 rear end, etc.
hectre13
Dec 11, 2023 08:14 AM
Thornburg
Aug 25, 2015 01:46 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Regal105
Aug 23, 2015 03:45 PM
Randomtask2
Aug 13, 2015 01:57 AM
