gears for a 87 iroc
gears for a 87 iroc
i have a 87 iroc with 2.73's right now i got the tpi 305 ho i am building up the car and thought gears would be a good stock i heard 4.10s are good gearsi am not realy worried about top speed i want to be able to take off on the start right now i can take most 350s in the long run but every car takes me off the start and it dont spin tire so i need a good set of gears and need to know how good they will take off on the start and a normal top speed or close thanks
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You will need to do a simple test to determine the best rear gear for acceleration, for your car. Run through a measured 1/4 mile
and observe the mph and rpm (in drive) as you cross the finish.
Divide your present gear ratio by the observed rpm and multiply
by the rated rpm @ peak horsepower.(assumes a stock motor)
eg: gear ratio 2.73:1, rpm @ end of 1/4 mile 3516, rpm @ rated
peak hp 4800
2.73 / 3516 X 4800 = 3.726
3.73 would be the best gear
This assumes that you have good traction to put the improved torque to the ground.
You may need a set of BFG drag radials of the same height as your present tires to get the effect your looking for.
peak hp 4800
Iroc8t8
May 4, 2026 08:09 PM
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
mustangman65_79
Aug 11, 2015 03:17 PM
