Speedo Gears
Old Dec 19, 2001 | 07:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Speedo Gears
I have an 85 IROC, 5-speed. I'm considering swapping my 3.23s to 3.42s. Do I need to swap both drive and driven gears to make the speedo read correctly?
JamesC
Old Dec 19, 2001 | 07:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Do you know what gears you have now? I think its a 7 tooth and a 18 tooth. You need a 19 tooth driven gear to go with the 7 tooth. Do a search on this board and you might even find the right GM part number.
Old Dec 20, 2001 | 04:05 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I think the drive gear is a purple color. If yours is the same then you should be good to go.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
