Mount supposed to look like this?
Car: 90 IROC, 95 Vette
1990 with a 305 TPI and automatic. Just curious if this is how the transmission mount is supposed to look? I'm getting a loud clunk when putting it into gear. I wasn't sure if that hole was always there or if it was a solid mount that is separating. Thanks.
Car: 88GTA
Engine: 5.7TPI
Re: Mount supposed to look like this?
looks pretty toasted
Put the brake on with the engine running with the hood up. Have a friend watch the motor when you put it in gear. If rear of motor rises up, it's the mount. That will cause a clunk at the tranny tunnel
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
If you need a new trans mount, most of the aftermarket rubber ones are junk, and the poly ones are hard as rock... I found one at Napa, see pic, far right, very good!
Also check toque arm mount... that one, I would switch for a poly, but you need to see which direction it's stamped (can be one of 2)...
Usually it's one of those 2 things...
Engine: 4++,350 & 305 CIs
Its hard to tell from the pic. You need to get under the car and push up on the trans tailshaft to see if the mount has seperated..
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The rubber tears away from the metal holding it. That's why a mount can look ok until you lift the trans a little.
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
