4L60E Trouble (Downshift Solenoid)
Old Oct 24, 2015 | 09:57 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
I had an issue a few months ago with my 3-2 downshift solenoid, which caused the car to start off in third gear.
I pulled and replaced all the solenoids and replaced the PCM, and everything seemed ok on multiple test drives. Drove the car two days ago, and had the same problem I experienced before. The difference, with the first PCM I experienced the problem IMMEDIATELY. With the stock LS1 PCM I'm not noticing the problem until much later.
I drove about 15 miles around town, and during the last 3 miles of the drive returning home it started acting up, and once again defaulted to third gear for all driving situations.
I can't find any breaks in the wiring...and would much rather not drop the pan a second time. Anyone have any other ideas as to what's going on?
The PCM I'm using was a spare unit, so I can't GUARANTEE that it's trouble free. So that's a potential problem. I'd rather not take the car in to have the transmission inspected, because I know a shop will simply say "rebuild it" and $1000 later I may or may not have the problem solved. Hopefully there's a 4L60E expert here who can help me out.
Old Oct 30, 2015 | 07:46 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: 4L60E Trouble (Downshift Solenoid)
Is the transmission harness ok and what year 4l60e because they make two different 3-2 down shift Solenoid
Old Oct 31, 2015 | 03:16 AM
Pro Built Automatics's Avatar
If the transmission was working ok before the problem, it is an electronic problem.
KarlJ
Nov 13, 2015 09:48 AM
KarlJ
Oct 9, 2015 03:43 PM
85cmroz28
Oct 4, 2015 09:44 PM
amcnellis
Sep 16, 2015 04:16 PM
Out-Cast
Sep 11, 2015 08:03 AM
