loud vibrating humming
Old Nov 12, 2015 | 09:39 PM
wllmswynn's Avatar
car vibrates and/or hums loudly when foots on lights on gas, just cruising, between 40-50mph. if I let up of the gas it stops; if I press harder on the gas it stops.
any ideas?
Old Nov 13, 2015 | 01:26 PM
Re: loud vibrating humming
U-joints, loose pinion nut, pinion bearings, extension housing bushing... for starters
Old Nov 13, 2015 | 05:32 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Losing the weight on the drive shaft might be a cause too.
Old Nov 14, 2015 | 01:44 PM
Balance won't come & go w gas pedal application. So, not applicable to this situation.
But, a good thing to look at in general, in vibe situations. And, if found, very easy to verify with a hose clamp; just put one on the DS with the screw where the weight used to be, and see if it's better. If so, add another. If so, add another. And so on, until it starts getting worse again; in which case, turn half of them one way and half the other a little bit, until you again go through the "optimum" dip in the vibe.
lt1z350
Wheels and Tires
32
Dec 1, 2015 03:19 PM
spoazzy1
Nov 15, 2015 12:12 AM
theking11863
Nov 14, 2015 06:23 AM
Jimmy2x
Nov 11, 2015 09:33 PM
Jacques101
Nov 8, 2015 04:43 PM
