slipping and stalling.. 2.8 700r4
Car: 1988 Camaro RS
Engine: 2.8L v6
Transmission: 700r4 stock?
Axle/Gears: peg leg one tire fire
on the way home I noticed the transmission was slipping 2nd and 3rd while going up a hill. I parked. then when I tried to drive again the car dropped rpm and didn't move unless i let off the gas. even in neutral the car jumps rpms. sometimes when it drops rpms I hear a high pitch whistle sound. checked the tranny fluid to be bone dry. added 2 quarts and didn't change a thing. any ideas what I'm looking into? thanks.
Re: slipping and stalling.. 2.8 700r4
A rebuild
Sounds like the clutch piston seals are smoked
Might want to go to youtube and watch the full series of videos by transmissionbench... very informative even if a bit repetitive and slow (don't need to watch every one of 17 pan bolts being loosened for example). Trans rebuild isn't magic or rocket surgery or anything; you can do it yourself most likely.
Car: 1991 RS
Engine: 5.0
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Have you been leaking trans fluid? It must have gone somewhere. Definitely smoked the trans.
Car: 90' Firebird
Engine: 3.1
Axle/Gears: 3.27 9-Bolt
I have a good trans and a 3.1 if you want to swap out everything!
I can meet you in Northern PA
89irocz355
101
Sep 19, 2016 04:05 AM
RubberDucky
Jan 22, 2016 07:20 AM
RED85TPI
Dec 11, 2015 09:55 AM
