clutch noise- scraping sound?
Car: 1983 Z-28
Engine: 305 LG4
Transmission: 5-speed
Trying to find out what this noise is... as soon as I start do depress the clutch, a constant scratching, scraping noise starts... kind of like a light grinding. It is constant in intensity. Stops as soon as I let off the pedal.
Any idea by this description alone? I don't know if it's the original clutch... car has about 138,000 mi.
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: clutch noise- scraping sound?
yep, as always, sofa hit it right on the head ... get it replaced asap or it is going to lock up or shatter soon
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
time for a new clutch , pressure plate , pilot bearing & throw out bearing . a good idea to have flywheel re-surfaced while replacing them . good luck ...
Car: 1983 Z-28
Engine: 305 LG4
The car had been modtly sitting for a good number of years. When I first got it going the clutch seemed frozen stuck. After a while it did start to engage/ disengage...
OK, so here's a dumber question... is there a clutch fluid reservoir under the hood?
Car: Pontiac Firebird 1989
Engine: 2.8 V6 (S)
Transmission: 5-Speed Manual
Dayum! I think i have the same issue which i posted on this link: https://www.thirdgen.org/forums/tran...-shifting.html
I guess its time for a new clutch. Im going to go for a maintenance soon so i can give you a feedback of the result! I have the same issue when switching gears. If i switch too fast then i can hear a scratching, grinding sound. If i do it slowly, i dont hear anything.
What if I have the exact same problem but I've installed everything brand new. I press the pedal and it makes the noise. I let off its normal, clutch works perfectly just loud scraping noise.??
Clutch installed wrong somehow.
Go back and check your work. Especially this.
Djmathis123
Dec 3, 2015 08:14 PM
