swapped 5.0L for 5.7L
Car: 1987 Iroc-Z
Engine: 350 tpi
Transmission: 5 speed std
Axle/Gears: 3:73
I have a 1987 IROC-Z currently with a 5.0L and T-5 manual tranny. I am putting on a 5.7L next week. I have the prom etc from the 5.7L. Question is...will the prom work with the 5 speed manual Trans? I know the 5.7L did not come with the manual Trans.
Re: swapped 5.0L for 5.7L
Didn't say that.
It will "work" as-is; whether it will be "ideal", or whether that automatically implies "need", is another matter entirely.
It will "work" as-is; whether it will be "ideal", or whether that automatically implies "need", is another matter entirely. Joined: Jul 2000
Car: `86 SS / `87 SS
It will stall.
Getting one programmed will get you closer to ideal.
Car: check
Engine: check
Transmission: check
If the PROM (MEMCAL actually) is from an '87 - '89 it will work. If it is from a '90 - '92 it won't work, different ECM.
RBob.
RBob.
Knight Prowl
Apr 5, 2021 09:10 PM
