need some suggestions,thanks
Old May 25, 2016 | 10:36 PM
luckydog0_18's Avatar
Car: 1986 camaro iroc-z28
ok i have a 86 iroc z28 witch is now a 350 carb swap 010 block with factory 700r4 trans with tci wiring kit. my problem is it wont shift at WOT but shifts fine under normal driving. any suggestions??
Old Jun 14, 2016 | 10:37 PM
Re: need some suggestions,thanks
wow almost a month and noone has ran into this issue that could give me some pointers? well thanks anyway on this one!
Old Jun 20, 2016 | 09:18 PM
thanks
Old Jun 20, 2016 | 09:28 PM
skinny z's Avatar
Sometimes these threads slip through the cracks. Like this one.
Start with the basics but
first, does the transmission have any modifications? Shift kit, upgraded boost valve, servo, etc?
The most obvious question here is: Has the TV cable been properly adjusted? Along with that, is the TV cable adjuster and connection to the carb all OEM is is there some aftermarket bracketry that has screwed up the correct geometry?
Old Jun 21, 2016 | 10:48 AM
the only modification that is has is the tci lock up for od and that was do to swapping the 305tpi out with the 350 carb. the tv cable has been adjusted correct but even done is several other times just to make sure. it does have aftermarket brackets they are show to be correct for the application. and it does shift ok when driving normal but if you take off" launch" and are wot it will not shift unless you let off the throttle.
Old Jun 21, 2016 | 11:14 AM
skinny z's Avatar
Unless the trans has been modified (and you say it hasn't) that's a classic case of an incorrectly set TV cable.
Being a carb swap, it's entirely likely that even though the adjustment appears correct, it might not be. The geometry is very specific. Check out tvmadeez.com. It gives all the dimensions and angles you need to properly set things up. If after all of that is 100% confirmed (and the symptoms fit this solution exactly) and you still have trouble, there may be internal issues with the trans. Stuck valve in the valve body, governor, etc.
I've gone through this same scenario with my 700R4 and the solution was another aftermarket bracket and another adjustment.
By the way, was the original equipment TPI?. There are two different TV cables used. One for TPI and another for TBI and carbs. The TPI won't work with a carbed application. That website I posted will give you the dimensions you'll need to verify. If you have the wrong cable ( or carb correcting bracket) you won't get the dimensions that they spec.
Let us know what you find out.
Old Jun 23, 2016 | 10:02 AM
skinny z's Avatar
Any news?
acerulz
Carburetors
Mar 30, 2016 09:04 AM
Onion
Mar 19, 2016 03:08 PM
mclenty0
Mar 19, 2016 11:36 AM
BeyondZ28_85
Mar 16, 2016 06:34 PM
1988_f-bird
Mar 15, 2016 01:06 AM
