Vibration Caused By Transmission?
Old Jun 3, 2016 | 10:04 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
So I've had a vibration for some time. It starts at 65-70, gets bad by 80, and is REALLY bad by 90.
Get to 80, feel the vibration, push in the clutch and it gets worse.
I chased it for some time, unsuccessfully. Got a 4th gen aluminum driveshaft, had it balanced and new universal joints; no change.
New rear tires (they were shot); no change.
New front tires (they were shot, and flat-spotted); no change.
Just had the driveshaft rebalanced up to 6,000 rpm; no change
I was thinking it was the rearend, but the guy I took it to put it up on jackstands and ran it, and says he can hear a ton of bearing noise coming from the center of the transmission.
Wonder if the transmission is causing my vibration.
Old Jun 3, 2016 | 07:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Vibration Caused By Transmission?
Have you checked for bent wheels or run out?
Old Jun 3, 2016 | 07:20 PM
Engine: L03 305 TBI
Yes.
Have balanced the tires both on, and off the car multiple times.
Have pulled the diff cover and inspected the rearend.
I got so disgusted with it I ended up parking the car for nearly 7 years.
I don't doubt it's the transmission, just wondering what could be wrong with the trans to cause a vibration like this.
Old Jun 3, 2016 | 09:01 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I'm no expert on t5s,but if you have a failed bearing in the transmission,the output shaft can wobble and cause huge amount of runout of driveshaft-sounds like it is time to get the tranny down and apart for a look...Before that you could drain the tranny oil and look for failed bearing debris in the oil...
Old Jun 4, 2016 | 09:29 AM
What kind of condition is the pilot bearing/bushing in?
sahlomonic
May 11, 2016 12:33 AM
stegal
Apr 6, 2016 03:33 PM
mfp189
Mar 22, 2016 07:09 PM
omarcamaro
Wheels and Tires
Mar 20, 2016 04:47 PM
mclenty0
Mar 20, 2016 06:50 AM
