TKO600 Swap and Factory Cross Member
Old Jun 5, 2016 | 06:14 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
For any of you who swapped in a TKO600. Did you use the Factory Cross member adapter plates that Fortes uses, or did you go with something different (Ie Spohn Cross member)
I have the Fortes Adapter plates, but cant seem to visualize how they work on the car with the factory cross member, so am contemplating picking up the Spohn.
Looking for any suggestions/gudance from anyone who has done the swap?
Thanks,
Dave
Old Jun 5, 2016 | 09:57 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: TKO600 Swap and Factory Cross Member
For the adapter are you talking about two machined aluminum block spacers? If so they mount in the factory crossmember holes with the studs installed in them and then the crossmember gets bolted to them. Problem is your pinion angle will be off slightly. What I and others on here have done is to cut the factory tunnel and raise it up where there is a clearance issue. That way you can use the factory crossmember with no adapters. I've been running my tko like this for s few years now.
Old Jun 5, 2016 | 10:15 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Hi Subroc, yes it is the machined aluminum block spacers. I kinda dont want to cut into the tunnel if not needed, but hear ya re the pinon angle.
Do you think I should figure out the spacers, or grab the Spohn xmember based off your experience with the swap - my preference is not to cut into the tunnel if I can get away without doing that.
Thanks for your help.
Old Jun 5, 2016 | 12:41 PM
subroc's Avatar
Engine: 355 TPI
I ran mine with the spacers for about a year of so. No real need to go to an aftermarket crossmember. What you might want to do however to avoid cutting the floor and using the spacers is to get yourself a Lakewood blowproof bellhousing. You do not need the bellhousing to trans adapter that way and since the trans is sitting that one inch further forward you do not need to cut the tunnel for clearance. You may just need to give it a few good hits with a hammer. Just one more avenue to look into. If you already have all the adapters and spacers however you might as well run them.
Old Jun 6, 2016 | 11:59 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Thanks,
Dave
I've had both over the years.
All the blocks do is move the x-member down and backward to set the trans mount in the right spot.
Currently, I have the Spohn x-member, but to be honest fits like **** and I had to grind the trans mount bolt hole quite a bit to get it to fit.
Old Jun 6, 2016 | 07:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I used a umi 700r4/t5 crossmember and packed it down 1/4" and it bolted on fine.
However, it sat a downward angle to the rear, didn't have enough height in the trans tunnel, so I cut the top of the tunnel and raised it a little and removed the spacers I added
dennisbernal91z
Apr 14, 2016 05:42 AM
Cehbra
Apr 9, 2016 04:19 AM
'91CamaroRS
Car Audio
Apr 3, 2016 07:45 PM
Spenc247
Apr 3, 2016 03:09 PM
neely8
Mar 27, 2016 01:17 PM
