Super t10 ---> th350
Old Jun 28, 2016 | 01:47 PM
Dustin_429's Avatar
Car: 1982 z28 camaro
Engine: 327
Transmission: borg warner super t10
Blew up my super t10 , first gear went out . Looking to buy a th350 or turbo 400 trans to swap in . Looking for something automatic that can handle abuse . And easy to find around for a decent price . What would be needed to do the swap? I find forums on going automatic to manual but nothing on going automatic
Old Jun 28, 2016 | 06:34 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Super t10 ---> th350
Any particular reason to switch to auto? I guess what I mean is your car is already set up for a standard trans so why not just put a beefier one in. A tko or t56 will handle loads of abuse.
Old Jun 28, 2016 | 08:22 PM
Dustin_429's Avatar
Engine: 327
Im 16 and have a crap job and am very limited on money . A friend has a th350 for 100$ . And it's behind a 327 that makes a little under 300hp to the flywheel
Old Jun 28, 2016 | 08:56 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I did this swap on my '82 back in the early '90s-as I recall was basicly bolt in using a B&M torque arm kit:cannot remember for sure if I used the t10 crossmember.TH 350 I used was bought as-is for $100 out of an '80 Camaro Since radiator had no cooler a separate cooler was mounted.For years afterward,car still had a clutch pedal along with the automatic shift...
Old Jun 28, 2016 | 09:46 PM
Dustin_429's Avatar
Engine: 327
Is the th350 water cooled ? And the stock torque arm won't bolt up now ? And will I have to pull engine to or just trans
Old Jun 28, 2016 | 10:06 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
stock setup is kinda water cooled-heated tranny fluid is circulated to a heat exchanger in the pass side radiator tank where it is cooled by engine coolant that has been cooled in the radiator.Add -on coolers are usually small radiators placed where there is decent airflow.Stock torque arm will not bolt to the TH350 without the B&M or similar kit,but can also mounted to the crossmember if you have the means to do this properly.Engine does not need moved.
Ellis87z28
Apr 7, 2016 06:50 PM
HEFF16
Apr 1, 2016 08:18 PM
the breeze
Apr 1, 2016 06:20 AM
MustangEater82
Mar 31, 2016 05:36 PM
Rpm92
Mar 30, 2016 09:20 PM
