LS swap question
Old Mar 31, 2016 | 07:22 PM
Ellis87z28's Avatar
LS swap question
With regards to doing an LS swap, are all LS engines in general the same? (Fittment and prosses of doing the swap) I could buy this
Please view this ad:
5.3L Ls motor,
http://www.kijiji.ca/v-engines-and-engine-parts/windsor-area-on/5-3l-ls-motor/1152289580
Price: $*800
Worth it? How do you actually go about doing the swap from a 305 tpi?
Old Apr 1, 2016 | 05:57 PM
Re: LS swap question
Fitment and all that, yes they are the same. Mounts, exhaust, trans bolt-up, etc.
$800CA sounds about right for a motor/trans pullout.
You take out the 305 TPI, and put the 5.3 in. Rotate all hardware counter-clockwise until loose. Installation is the reverse of removal.
You'll need a different oil pan, torque arm arrangement, crossmember if memory serves, and probably accessory mounts for the front of the motor (the truck stuff is up too high and the hood won't close on it).
Old Apr 7, 2016 | 06:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Two suggestions:
1) Read up and post in the LTX and LSX engine swap subforum (where this is now).
2) Read the LS1 Swap sticky in the top section of the subforum. It includes info on starting with a truck engine.
Carystone92
Apr 21, 2016 06:08 PM
RSarge
Feb 22, 2016 03:56 PM
Night rider327
Feb 17, 2016 09:22 AM
Night rider327
Feb 16, 2016 12:01 AM
Zylinder
Feb 12, 2016 12:00 PM
