Disc brakes on old 12 bolt?
Old Jul 18, 2016 | 12:16 AM
CamaroChase's Avatar
Car: 1989 RS, currently bone stock
Engine: 305 TBI
Transmission: Th700R4
Axle/Gears: None at the moment, bad accident
Hey guys, I've started massing hardware for my LS swap and am now looking for a replacement rear end to handle the torque/traction. I have a factory disk brake GM 10-bolt now, (not sure what year, was swapped in by someone else) and would like to keep the disc brakes if possible to cut down on the swap cost. The rear ends I'm looking at are all old 12 bolts (60s and 70s era) that can be had for cheap. Is there any reason not to go with these rear ends? also, can my brakes be adapted to fit with custom axles? I'm on a tight budget and I don't know much about this stuff, so any advice is appreciated.
Old Jul 18, 2016 | 06:18 AM
Re: Disc brakes on old 12 bolt?
The problem you will need to solve will be, the hole in the center of the backing plate won't fit over the axle bearing.
That of course, will come after figuring out torque arm provisions. Get that handled first, then move to brakes.
If they're the ones with cast-iron calipers, don't bother.
Old Jul 18, 2016 | 06:56 AM
big gear head's Avatar
I don't know what 12 bolt rear ends you are looking at, but I haven't seen any cheap Chevy car 12 bolt rear ends in many years. Basic rebuildable housings are going for around $500 and up now days.
The car 12 bolt uses the very same axle bearings and seals as the 7.5 10 bolt. The 4 bolt brake bolt pattern is also the same. The hub in the center of the axle should be checked along with the outside diameter of the axle flange to be sure that the brake rotor will fit the axle. Axle hang out is the same at 2 3/4 inches.
Old Jul 20, 2016 | 10:00 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 89-92 rear discs fit a 12-bolt pretty handily.
68-72 A-body housings aren't cheap these days most of the time. Seriously look into a ready-to-bolt-in new assembly if you're serious. The effort to adapt a non-torque arm rear will suck up time and have no benefit in the end over a housing that's ready to go and correct width.
Old Jul 21, 2016 | 06:56 AM
Agreed. There are many after market 12 bolt rear end that will bolt in, and they are stronger than the Chevy rear ends.
88 vert guy
Brakes
Jul 14, 2017 09:13 PM
propaintball96
Fabrication
Apr 4, 2016 01:18 PM
jdhh74
Apr 1, 2016 05:50 PM
Gambit TA
Apr 1, 2016 05:18 PM
Vinscully50
Mar 15, 2016 03:25 AM
