Manual Transmission Maintenance?
Old Dec 27, 2001 | 09:14 PM
RS91's Avatar
It's been 10yr. And I havn't done anything for my manual trany... What is the best thing to do and how do I do it...
Thanks..
Old Dec 27, 2001 | 10:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Change the fluid regularly... yours should use ATF. That, and replace the clutch when it screws up, is about it. There's not much else to do.
Old Dec 28, 2001 | 08:38 AM
RS91's Avatar
ATF? isn't that Automatic Transmission Fluid???
Old Dec 28, 2001 | 09:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would be correct. The earlier units with brass synchros used gear lube; the 87-up ones with compostion synchros (same material as the clutches in an auto trans actually) use ATF.
Old Dec 28, 2001 | 04:49 PM
RS91's Avatar
One more question. Is it safe to use on manual tranny?
Old Dec 29, 2001 | 01:31 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Yea it's safe. That's what the previous post is telling you. And don't use gear oil in a transmission that was designed for ATF.
Old Dec 29, 2001 | 06:53 AM
RS91's Avatar
Thanks alot guys...
Old Dec 29, 2001 | 07:38 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
My 1987 doesn't have a dip stick for the ATF so I have always thought that it used the older style gear. Is this correct, or is mine somehow a little different (it is the standard 5-speed tranny matched up to the LG4-304)?
Old Dec 29, 2001 | 09:34 PM
92zeddar's Avatar
how many litre's does a T-5 take to refill??
Old Dec 29, 2001 | 11:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No manual trans in a car has a dipstick, that I know of. A 87 car, LG4 or whatever, should have the newer style trans that uses ATF, dipstick or no. To check the level, take out the plug that's about 2/3 of the way up on the pass side of the trans, and stick our finger in there, and see where the fluid level is. Or just add fluid until it runs out, that's about as good a check as any... you know it's full when you get done.
It takes about 2½ quarts to fill one of these.
Old Dec 30, 2001 | 02:53 AM
RS91's Avatar
Is there away to drain a manual tranny???
Old Dec 30, 2001 | 10:02 AM
gravitar's Avatar
My Camaro is an A4, but on all the T5s and other manuals I've seen, there's two plugs. One's at the bottom for draining it completely. The one further up is the "fill line".
Old Dec 30, 2001 | 03:48 PM
RS91's Avatar
Thanks I will look into this.....
Old Dec 30, 2001 | 04:59 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Just did this not too long ago, you'll need about 4 qts ATF if you use the method mentioned in the earlier posts.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
