Did I install the seal too far?
Old Sep 25, 2016 | 04:09 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Hey everyone,
Just put new bearings and seals in. Installed the bearing as far as the shoulder inside the axle tube - no worries there.
But I think I installed the seal a little too far as per the picture. I discovered after installing that it should be flush with the tube and not recessed - I installed the seal as far as they would go. Am I going to have to remove the seal and install a new one?
Old Sep 25, 2016 | 04:42 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Did I install the seal too far?
There is an inner and outer lip edge on the inner face of the seal.
If both are on smooth axle surface, you're good.
Old Sep 25, 2016 | 06:06 PM
Car: 1989 Trans Am
Oh cool, thanks for that. Was just worried for a bit that I had to do it again.
Old Sep 25, 2016 | 08:22 PM
big gear head's Avatar
It's fine like it is.
Old Sep 25, 2016 | 09:53 PM
Car: 1989 Trans Am
Thank you.
dennisbernal91z
Fabrication
25
Mar 20, 2017 08:42 AM
MSgt Luttrell
Nov 4, 2016 11:28 AM
cougar20th
Oct 16, 2016 12:10 PM
blacksunshine'91
Oct 10, 2016 07:39 PM
chas0218
Sep 22, 2016 12:26 PM
