PROBUILT,TRANSFIXLEO,or anyone who knows:TC lockup without ecm
Old Dec 28, 2001 | 06:26 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I pulled out the ecm when I swapped in my current motor.I still have the 700r4 with a 2500 stall lockup converter.Which wires on the tranny harness are the ones I need to lock up the converter with a switch? My mileage sucks as it is,so I would like to lock up the converter since I do a lot of highway driving.Thanks for any help.
Old Dec 28, 2001 | 07:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Power to A, ground to D.
Old Dec 28, 2001 | 08:35 PM
RSpeed's Avatar
Thanx.So on the four pin connector at the tranny,they are marked A-D,right?
Old Dec 28, 2001 | 09:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, if you have the original connector, you can pop the shell open to see the markings. They're pretty small though.
Old Dec 29, 2001 | 12:49 AM
RSpeed's Avatar
Great.That's just what I needed to know.Thanks Apeiron.
Old Dec 29, 2001 | 01:48 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't even have to touch it if you don't want to, even without the ECM you can still put a switch in the wires to the ALDL under the dash.
Old Dec 29, 2001 | 02:51 AM
Pro Built Automatics's Avatar
Use the GM vacuum switch PN 14014519 & GM connecter PN 12102606. Install the vacuum switch on the fire wall and a vacuum hose to a true vacuum source. Hook one wire to the battery (use resistor wire) & the other to the "A" pin in the plug at the transmission, it is the outer pin in the plug toward the front of the vehicle. You might have to make a ground, install it then see if its needed. Make sure engine/transmission is itself grounded to the frame with a strap.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
