non computer t 700 r4 ????
Old Dec 30, 2001 | 11:25 PM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
which t700 r4 can i use in a non computer 82 z/28 with standard dash gauges,,,speedometer,,,tacho,,, no computer at all on this car ,,,carb engine,only
Old Dec 31, 2001 | 03:52 AM
transfixleo's Avatar
Actually that IS a computer car, just not completely controlling the tranny, just L/U. While you can bolt in any V8 tranny except the 'Vette, it will not work correctly as a Z-28 tranny. Where is the original tranny?
Old Dec 31, 2001 | 06:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, he's in Australia. His car probably really doesn't have a computer.
Old Dec 31, 2001 | 07:07 PM
lukerene's Avatar
this car had a very sad 3 speed auto,,,i would like to install a t,700r4 in replace of the old metric 3 speed ,,,,this car has no computer at all its removed,completely,,,and the car is opperating just like an early model chevy,is there a specific model 700r4 which can be installed in ,, for an example ,,,say a 70 model 350 camaro,,,,
Old Dec 31, 2001 | 07:25 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
almost everything will work all of your cars components. The Tq converter wont lock up which is not big deal just put a cooler on it. You could use your crossmember if you are handy and want to make the 700r4 mount fit. You will need a drive shaft for the 700r4. I cant remember how long it is in inches but im thinking a full size rwd caprice (7r4) has the same lengh drive shaft.
SSC
Old Jan 2, 2002 | 07:54 AM
82camaro's Avatar
Car: 82 camaro SC
Any 700r4 will work just fine. The only electronic part of the 700r4 is the torque converter lock-up. The lock-up is the easy part--all you need is a manual on/off switch or a lock-up kit from TCI(70 bucks) to automatically control it. The crossmember will need to be modified and a later model 3rd gen driveshaft(700r4/t5) will need to be used.
Old Jan 2, 2002 | 02:37 PM
Pro Built Automatics's Avatar
Use the GM vacuum switch PN 14014519 & GM connecter PN 12102606. Install the vacuum switch on the fire wall and a vacuum hose to a true vacuum source. Hook one wire to the battery (use resistor wire) & the other to the "A" pin in the plug at the transmission, it is the outer pin in the plug toward the front of the vehicle. You might have to make a ground, install it then see if its needed. Make sure engine/transmission is itself grounded to the frame with a strap. Now it will lock & unlock automatically.
Old Jan 2, 2002 | 02:56 PM
E-Z Rollin's Avatar
Re: non computer t 700 r4 ????
Originally posted by lukerene
which t700 r4 can i use in a non computer 82 z/28 with standard dash gauges,,,speedometer,,,tacho,,, no computer at all on this car ,,,carb engine,only onfused:
The 88-92 700r4 is the best choice, they use a t.v. cable to control shifts and have the factory upgrades. Don't confuse the 700r4 with the 93 up 4L60E which is comuter controled,lot's of people do!
Old Jan 3, 2002 | 02:41 AM
lukerene's Avatar
thanks boys aussie z/28
cool,,,no worries,,,,,i am not familliar with these 4 speed auto,s,had plenty of th/350,s 400,s ,not many use these here in hotrods,,,early non computer cars,,,,and its hard to get information here this time of the year,,,,most are on hollidays,,,long as this thing drives ,,,and changes,,,i recon it will work fine,,,,cant waite,,,,
Old Jan 3, 2002 | 04:52 PM
johnyIROC's Avatar
I have been told by a few places that you have to use a 700R4 out of a Camaro because they have a special tailstock for the torque arm.... does anyone know if this is true?
Old Jan 3, 2002 | 05:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes it is true, but you can just swap the tailhousing over if you can find one.
Old Jan 4, 2002 | 03:01 AM
lukerene's Avatar
yeh i can get one from america,,,,and get this thing happening,,,you guys have been great,,,steve in smokey sydney
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
