t5 to t56 help
Old Apr 9, 2017 | 01:00 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
t5 to t56 help
I have a 88 gta factory t5
I have a full t56 swap ready to go used
now I got the lt1 slave and master
but can I resue my t5 slave and master
I replaced them new a few years ago
Old Apr 9, 2017 | 03:03 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t5 to t56 help
You need to verify the pushrod length and bore to answer your question.
Old Apr 9, 2017 | 08:04 PM
bensbaby's Avatar
Engine: 383 built
Re: t5 to t56 help
I have the t56 one and the whole new t5 so when I get into it im gonna try to use my t5 stuff
Old Apr 10, 2017 | 07:48 AM
Re: t5 to t56 help
The T-5 line isn't anywhere near long enough.
The T-56 stuff is just altogether better in every way. Lay them next to each other and look. I think the choice will be clear. Only problem will be, the eyelet on the master push rod doesn't fit the 3rd gen pedal stud right; and, the 3rd gen stud is too far from the pivot, which makes it stroke the master too far, which makes the pedal action kinda high.
Old Apr 10, 2017 | 08:36 AM
BOTTLEDZ28's Avatar
Transmission: A4
Re: t5 to t56 help
I did this swap back in 2002 on a factory T5 car. You cannot use the T5 slave and master. Just go buy a brand new one from the dealer unless you can find a used one in great working condition. The one I bought from the dealer already had fluid in it and was ready to bolt right in.
I also used the 3rd gen pedals. I vaguely remember having to make some slight modification to the either the stud on the pedal or the eyelet on the rod. I think I also had to modify the retaining the clip. At the time I did the swap, not many guys here had done it. If I did the swap again, I would use 4th gen pedals.
