85 S-10 4.10's in a 84 Z28 10 bolt?
I recently removed some 4.10's from a 85 s-10 10 bolt.Got the whole carrier but it is not posi.
My camaro has a 3.23 ratio.(non posi)
Can i just swap out center sections and use these 4.10's?
It depends on what year camaro you have. The S-10 parts you have are for use with 26 spline axles. I think they changed to 28 spline sometime in 1988 on all 7.5 an 7 5/8 rears.
Either way you should be able to use just the gears, I have an auburn posi in my '87 S-10 and it says for use with 2.73 and up gears, I have 3.73's on it. So, according to them, I could use 4.10's on it also, it should be the same series as both of yours.
So yes, they should fit.
Thanks for the info guys.
SSC,i believe the truck was a 84 or 85.
It was a 2wd with a 4 cyl manual trans.
The parts truck was missing the RPO sticker but with the manual trans it had i was expecting 3.73's.
Not the case with this one.
I had to think for a second after i got the cover off......stamped 9:37.So let me see,9 goes into 37, 4.10 times.I'll take em
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
