9 Bolt: Torco type G needed?
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Hello everybody
I'm in the need of an advice about changing oil to my differential. I have a GTA so the 9 bolt. I was told to use something like 80w90, and maybe to add the TORCO Limited Slip DIFF G type.
Is the torco additive needed? Can I just use the 80w90?
thank you very much
thank you very much
Car: '87 FIREGOOSE!!!!
Re: 9 Bolt: Torco type G needed?
I have always added the additive, even though I put Royal Purple in and they say it's not needed, why not, can only help. It's not really a big bottle anyway, so I think it's always a good idea.
The Torco TGO works best in the Borg Warner rear ends. This is the only oil that seems to work in the '04 to '06 GTO, which also has the Borg Warner. If you can find this oil I think you will like it.
It's not bad if you are just doing the carrier and not the gears (you must already have 3 series gears) Takes about 3-4 hours I would say. Here's my thread:
https://www.thirdgen.org/forums/tran...rg-warner.html
GD
GD
Engine: 4++,350 & 305 CIs
Following dot.
