Need help identifying transmission part
Old Jul 16, 2017 | 06:56 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
This circular part on my transmission has been dripping fluid for about a year now. What part is it?
Attached Thumbnails Need help identifying transmission part-20170716_160642.jpg
Old Jul 16, 2017 | 07:15 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need help identifying transmission part
Vehicle speed sensor.
Old Jul 16, 2017 | 07:54 PM
Car: 1991 Z28
Thanks! Ouch at $82 for a replacement at Advanced Auto. Do you know if there is a fix for a leak on this part without buying a new part?
Old Jul 16, 2017 | 07:58 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Can't you just buy a new seal, or is it leaking through the body or electrical connection?
Old Jul 17, 2017 | 09:20 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
There is an O ring on the body replace that
Old Jul 17, 2017 | 02:45 PM
Car: 1991 Z28
I think it may be leaking out of the body itself but I will start with the O-Ring.
Old Jul 17, 2017 | 04:58 PM
Pro Built Automatics's Avatar
If you need to replace it, call Teal Automotive and ask for Sheryl, and tell her I sent you and she will give you the part at my cost. 765 768-7726 EST in Dunkirk, Indiana.
Old Jul 19, 2017 | 05:58 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
That is some nice clean aluminum . What have you been cleaning the aluminum with?
Old Aug 2, 2017 | 05:22 PM
Car: 1991 Z28
I've never touched it. The transmission shop that rebuilt it may have cleaned it off but it wasn't that dirty to begin with somehow.
I'm going to take a shot at replacing the oring this weekend. Will a parts store have the oring in stock or should I be looking for it online? An online search hasn't turned up a whole lot so far.
Old Aug 2, 2017 | 05:49 PM
GeneralDisorder's Avatar
http://www.monstertransmission.com/7...l#.WYJW-oTyuUk
GD
Old Aug 2, 2017 | 06:42 PM
Car: 1991 Z28
$14.95 to ship a $2 part to my house....I guess I better keep looking.
Edit: Never mind I cracked and decided that the time I would waste calling around town hoping to get lucky wouldn't be worth just spending the $17. Thanks for the link!
Old Aug 21, 2017 | 06:32 PM
Car: 1991 Z28
I installed the new oring and I still have the leak. It's hard to find the source of the leak but I think it's leaking from the sensor body itself.
Old Aug 22, 2017 | 03:48 AM
Lurbie's Avatar
Car: 89 Camaro
If you have to buy a sensor from Advance, buy it online with their 30% or 40% off coupon and just pick it up in store. It's been awhile since I've used those codes, but the 40% may require $100 purchase. Just Google search the discount codes, but I think they were TRT30 and TRT40 if they still work.
