T5 shifter replacement questions
Car: 1991 Camaro RS B4C
Engine: 5.7 TPI Crate Motor
Transmission: WC T5
Axle/Gears: 10 Bolt 3.42
I am going to replace the shifter in my car with another stock one because the original one was butchered. Are there any instructions on how to do this? Any maintenance items I can do while I have it off such as, shifter bushing, and shifter fork? Any help is appreciated.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: T5 shifter replacement questions
Unbolt the stock shifter 4 bolts, remove and replace shifter of your choice. You can replace the shift cup, upper and lower boot while at it.
Car: `86 SS / `87 SS
The shift bushing in a T5 is okay to replace with out epoxy, but use some adhesive if you have some. I like the stock nylon type. Forks are internal.
Transmission: WC T5
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Make sure the Trans is in neutral too.
