gear upgrade recommendation!
Old Aug 12, 2017 | 04:24 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
I'm thinking about upgrading my stock 2:73's in my 91 GTA, any suggestions what to upgrade too? Recommended vendors? Links?
Car is pretty much stock.
Old Aug 12, 2017 | 08:51 PM
big gear head's Avatar
Re: gear upgrade recommendation!
Are you going to upgrade the differential too?
Quick Performance has some good kits to do the whole thing. They sell the Yukon Dura Grip with Motive gears and the USA Standard installation kit. These are all pretty high quality parts and you can't beat their prices.
The 3.42 gear is pretty popular.
Your '91 should have the 7.6 rear end with 28 spline axles. http://www.quickperformance.com/GM-7...t_p_20409.html
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
With a 700R4 3:42 is probably the best overall choice (assuming you have a TPI motor) with 3:73's it's spinning a bit fast to be in peak torque at hwy speeds... I tries both with my L98 and was happiest with the 3:42's
Old Aug 12, 2017 | 10:44 PM
Pro Built Automatics's Avatar
If you like the gas mileage and the low rpm's on the highway of the 2.73's, go to a 2,400 - 2,500 rpm stall torque converter. You will get a lot more off the line without losing the advantages of the 2.73's. If you want to add a posi., that would be fine.
Old Aug 13, 2017 | 02:54 PM
Engine: V8 305
thanks guys.. gas mileage is not the main concern.. i just hate the car gearing down on every hill lol.
Old Aug 13, 2017 | 08:38 PM
GeneralDisorder's Avatar
I went to 3000 stall converter and 3.70 and I enjoy it quite a bit.
GD
Old Aug 13, 2017 | 09:01 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
i tried to go to 355s on mine. the shop took it apart and then realized that 355s wont fit in the stock housing. he put it all back together then called me and said I needed to buy a new carrier. I would have too if it hadn't taken him 2 weeks to get to that point. I was tired of not having the car. he originally said 2 days
Old Aug 13, 2017 | 09:13 PM
The housing wasn't the problem. You just needed a 3 series differential.
Old Aug 14, 2017 | 11:44 PM
Evilokc's Avatar
Engine: tbi 305
a 3 series? I'm sure I will still upgrade the gears just not sure to what or when now.
Old Sep 17, 2017 | 08:51 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
2600-3000 converter
3.42 - 3.73 gears
Nice combination
Old Sep 17, 2017 | 09:38 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
3.42 is a great gear choice - many have moved to 3.73 and later realized that it is overgeared for the stock TPI power band and kills top speed.
Old Sep 18, 2017 | 08:23 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I went 3.73s, an S10 torque converter, corvette servo and shift kit to go along with it. Feels like a different car. 3.42s would be a better choice though I do agree.
Old Sep 18, 2017 | 09:05 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
For a daily driver, I'd want 3.42's.
For the car in my sig, 3.73's are perfect; it's an occasional driver, sometimes 200+ mile trips, and a bracket race / test'n'tune toy. 3.73's don't really hurt the mileage much. I can still squeeze 26 mpg out of it .....if I try
With a more radical motor setup for primarily strip use, 4.10's would be logical.
