4th Gen pedals top mounting bolt
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Re: 4th Gen pedals top mounting bolt
When I swapped in my 4 gen pedals I never put the top bolt in. So far no issues.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
It's a really good idea to use it. Since when you push on the pedals, essentially the pedal assembly is putting even more stress on the non-reinforced firewall. The screw in the top helps to stop the assembly from wanting to rotate downward.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The top bolt doesn't line up exactly where the factory hole is, so you need to either elongate the hole in the pedal brscket to match, or cut it off and re weld it, or drill a new hole in the dash frame and use a new self threading or swadgeform screw to mount it.
