Zexel swap
Old Dec 22, 2017 | 09:11 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Zexel swap
Getting ready to swap out my old peg leg rear end to my new zexel ls1 rear end with disc brakes. Have a few questions about the swap. As for the brakes, Do I need to swap out the brake booster too? or just hook up the lines and thats it.? Will my v6 brake booster work the same with rear brakes? Also on the zexel rear end , whats the best oil to use? I heard that you should only use synthetic oil with the posi additive. Is that right.? Anything else i need to do before i do the swap ?
Old Dec 22, 2017 | 09:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Zexel swap
Zexel torsion limited slip device is a gear type posi, no clutch packs so why would you need additive?
The stock booster is fine, you "should" find a proportioning valve for a disc/disc car 89-92, or replumb the lines, connecting the fronts directly together and install an adjustable valve to tune the rears.
You need parking brake cables from hawks for the conversion as well.
You may have to mod9fy the brake lines on the axle if it's from a car with 4 channel abs
Old Dec 22, 2017 | 11:15 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Re: Zexel swap
Cool. What fluid would you recommend for the zexel? As for the parking brake cables, can I just grab some of a 4th gen camaro? Was at the junkyard the other day and l saw plenty of candidates. As for the prop valve, I was reading and lot of people saying i should be fine with my stock valve. Its a 92 v6 . If not, can i just grab one off a 4th gen as well?
Old Dec 23, 2017 | 09:55 AM
big gear head's Avatar
Re: Zexel swap
Any 80W90 or 75W90 gear oil will work with that differential. You do not need any limited slip additive. If you want to use synthetic then Mobile 1 is a good one. I've been using Lucas a lot lately. Torco is another brand that I like, especially with the Borg Warner differentials, but it's hard to find.
Old Dec 23, 2017 | 09:18 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Zexel swap
See what Chevrolet recommends. 2002 Camaro Owner Manual PDF here, page 342. Column on the right, Rear Axle (Limited Slip Differential).
https://my.chevrolet.com/content/dam...aro_owners.pdf
Old Dec 23, 2017 | 09:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Zexel swap
4th Gen cables will not work.
The prop valve will "work". But the proper valve will work better.
4 th Gen cars do not use a comparable valve.
Old Dec 25, 2017 | 10:52 AM
cmm7v3's Avatar
Car: 92 Camaro RS
Engine: 1JZ-GTE
Transmission: R154
Re: Zexel swap
I ran a wilwood adjustable valve with mine. I had to get the custom ebrake cables, its been so long ago I forgot who makes them.
Jackrabbit501
Aug 24, 2014 01:03 PM
LS1Formula
Feb 18, 2004 08:06 PM
Cliff92Z
Aftermarket Product Review
Mar 29, 2001 08:15 AM
BLUE92RS
Nov 6, 2000 09:04 PM
BLUE92RS
Oct 30, 2000 07:34 PM
