B&M MegaShifter
Old Jan 4, 2002 | 04:43 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
B&M MegaShifter
Since i can't find a shop to install this thing, how the heck do i do it myself. It looks hard from the instructions and i don't want to screw up my tranny. Pleae, if anyone here has done this on a 350tpi with 700r4, please give me exact instructions. Thanks.
Old Jan 4, 2002 | 04:54 PM
SoCo80p's Avatar
it should all be in the instructions on what to do, its not too bad of a job but a little bit, probley have to modify your consol a bit also but im not for sure.
Old Jan 4, 2002 | 07:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would suggest using the stock cable that way you won't even have to get under the car. Plus, I hear the cable they give you is crap. Took my Dad 3 hrs to install. You'll have to cut a bracket off the shifters and drill a hole to use the old bracket in order to use the stock cable. Use locktite on the handle so it won't strip, and never ever put armorol on the boot, it will crack.
unknown_host
Aftermarket Product Review
Aug 11, 2001 08:44 AM
jayman350
May 18, 2001 08:23 PM
jimbo
Mar 14, 2001 05:35 AM
STL1994
Feb 17, 2001 02:41 AM
Fastbird
Nov 5, 2000 10:47 AM
