4th gen 10bolt?
Old Feb 6, 2018 | 12:57 PM
StunMan's Avatar
Car: '91 RS vert
Engine: mild TBI 305
Axle/Gears: 3.43 pos
4th gen 10bolt?
decided to go bigger tires,brakes, and gear ratio
Swapping in a 4th gen rear end.
Decided on a '98-'02, 3.42, posi rear end. Not as rare as the 3.73s
Found '00 one with all the right RPO codes GU6, G80, appears unmolested
On inspection looks good, but does not turn the axles as a posi
Question; Do the later geared posi units behave different? worn out?
Car is a V6, unmolested, and not modified by previous owner
Old Feb 6, 2018 | 01:11 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: 4th gen 10bolt?
Hold a lil bind on the other side see doesnt it then try to turn it
sack23
Mar 4, 2013 03:02 PM
82crossfire305
Jan 9, 2013 09:12 PM
89305formula
Oct 21, 2007 10:30 PM
tpivette89
Oct 11, 2006 08:58 PM
N8MAN1068
Aug 4, 2006 04:09 PM
