GM's 4l75e disection!
Old Feb 19, 2018 | 11:10 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Hey guys I just received a 4L75E and have to swap out the output shaft to make it work in a 4WD application.
I've only rebuilt 10 or so 60E's and don't have endless knowledge on them. If you guys would like to know what is in one I would be happy to oblige. The issue being I don't know everything to look for especially in the valve body.
So, I will post some pics of what I see and if you want to see more or have me look at something specific please chime in!
Old Feb 19, 2018 | 03:00 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Re: GM's 4l75e disection!
Here's what I have apart now.
The 2nd and 4th servos are the Sonnax Super Holds. I'm not sure if the 2nd servo comes with the springs already in it so I took it apart to see which ones were there.
I'm thinking the 2-3 shift valve is also the Sonnax Heavy Duty
2-3 Shift Valve. (Based on the hole in VB wall) I don't have it apart yet to inspect.
The 1-2 accumulator valve has the YZ stamp in it which I believe is just the latest one they are using. (correct me if I'm wrong)
Attached Thumbnails GM's 4l75e disection!-img_6701.jpg   GM's 4l75e disection!-img_6715.jpg   GM's 4l75e disection!-img_6712.jpg   GM's 4l75e disection!-img_6718.jpg   GM's 4l75e disection!-img_6722.jpg
Ovrclck350
Mar 11, 2003 09:36 PM
