88 GTA with 4l60e and "Little Black Box" ?
Old Mar 6, 2018 | 12:09 PM
2012sergen11's Avatar
Car: 1987 Trans Am
Just picked up an 88 gta that had a 4l60e swapped in. The previous owner had a box hooked up to make it full manual shift. Car is running the stock 350 tpi. Anyone else have experience with this and should i look at getting the box for it or are there other options? (Aside from swapping a 700r4 back in)
Old Mar 9, 2018 | 09:27 PM
Car: 1987 Trans Am
Re: 88 GTA with 4l60e and "Little Black Box" ?
Nobody ?
Old Mar 9, 2018 | 09:36 PM
Drew's Avatar
Sounds like a solution looking for a problem. I suppose if a person had a free 4L60e and a thirdgen that needed an auto trans, it might be worth buying an aftermarket unit to control the electronic valve body. But why? Put that $600 towards a 700R4 or 4L60 (without the E) and you're half way to a transmission that will bolt right in.
Old Mar 9, 2018 | 09:41 PM
Car: 1987 Trans Am
I guess in a way the trans is "free" because it is already in the car. The question is then do I use a controller or this box for it or pull it and buy a 700r4. I can get the box for 150 or so but would rather not run it if it will cause other problems
Old Mar 16, 2018 | 10:39 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
There are aftermarket controllers to run a 4L60E?
And with tuning experience, a 94-95 v6/v8 truck PCM can be used to control the EFI and trans.
Old Mar 17, 2018 | 06:56 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I think some years GM diesel pickup trucks run a stand alone box to run the "E" trans and it can work for you. Will have to do more research on it to be sure.
Old Mar 17, 2018 | 10:48 AM
jmd's Avatar
jmd
True. Minor wiring changes are needed for a 4L80E controller to work on the 4L80E.
Old Apr 10, 2018 | 09:55 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
If you don't like whatever 'box' they have, pick up a Microsquirt 4l60E controller and call it a day.
The E-trans gives you a lot more control over part throttle and wide open throttle shift points, shift delay, etc. Definitely better than a 700R4.
-- Joe
SomethingWild
Dec 14, 2011 08:23 PM
Street Lethal
Mar 21, 2008 12:35 PM
topher
Feb 4, 2003 11:17 AM
FBODY-ADDICT
Jul 31, 2001 10:17 PM
