Electronic speed sensor/gear swap
Old Mar 17, 2018 | 07:16 PM
fshutz's Avatar
I swapped out the 2.73 gears in favor of the 3.42 (posi) in my 89' t/a, 5.0L TPI - automatic. I believe I have the correct gears (17 red and 44/ light green) But Im running into a problem with the "electronic" speed sensor. My old sensor has the 34-39 stamping on it and I need the 40 & up in a non-cable driven sensor to get the speedo in sync. Any one know of a fix for this? These sensors appear to be hard to find. Someone mentioned that I may need the one from a vette of the same era. Thanks a lot fellas
Old Mar 17, 2018 | 07:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Electronic speed sensor/gear swap
I believe the dakota digital sgi-5 is the easy solution.
Amazon Amazon
Old Mar 18, 2018 | 02:47 AM
GeneralDisorder's Avatar
https://www.amazon.com/Dakota-Digita.../dp/B014N07F8W
+1
That's how I changed from 2.77 to 3.70 on my 86 TA. Works great.
Use shielded wire for the signal or you get speedo jumping while stopped at a light.
GD
Old Mar 18, 2018 | 09:13 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Did you try to install the gears onto the sender you have? I was able to use my stock one when I went from 2:73-3:73. I believe my stock gears were red/red
Old Mar 18, 2018 | 09:44 AM
Tibo's Avatar
Car: 1991 Z28 Vert
GD
You should see how noisy our ignitions are, exact same reason. Good advice.
Old Mar 22, 2018 | 06:50 PM
fshutz's Avatar
Thanks fellas, it looks like the Dakota box is the only way to go. I was hoping there was an accommodating elect. speed sensor that I could pop in (along w/ the right gears) in the tail shaft for the 40-45 count. Sucks thats all I know.
twigger
Feb 17, 2012 05:49 PM
jcon104
May 27, 2010 12:33 PM
Golden80
Apr 22, 2001 02:10 AM
ckcam310
Sep 17, 2000 09:24 PM
