93-95 v6 700r4 compatible with 92 3.1
Old Mar 17, 2018 | 11:56 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I'm looking to swap out my old worn but still functional auto trans for another auto trans or maybe a 5 speed when my current transmission gives out. Question? Can I yank one out of a 93-95 3.4 v6? I'm assuming its the same trans for the auto. Basically take out old and stick in newer, plug and play same thing right. 5 speed would be different of course.
Old Mar 18, 2018 | 09:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 93-95 v6 700r4 compatible with 92 3.1
I believe that those will be E transmissions (4L60E). Will need a controller to run it. Although it will bolt up without issues.
RBob.
Old Mar 18, 2018 | 02:34 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Id I do end up picking one of these up what would I need to make it work with my 92 3.1
Old Mar 18, 2018 | 02:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.summitracing.com/search/...on-Type/4L60E/
Old Mar 20, 2018 | 02:12 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Passenger car 1993 models were a 4L60 without the E, and had different TCC wiring. The VSS may differ, too.
1993-up truck and 1994-up car versions were the 4L60E. Controller required.
Lowrider0308
Sep 19, 2006 04:42 PM
MikeH
Nov 26, 2001 08:12 PM
MotorCityMuscle
Oct 27, 2001 04:27 PM
Zepher
Oct 12, 2001 11:18 PM
Night Hawk
Nov 12, 2000 12:00 PM
