What Winbin ECU file is compatible with my setup?
Old Oct 11, 2001 | 10:31 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Ok, here is what I have.
86 Trans Am 305 5speed originally an LG4. Now it has an 87 TPI setup converted to Speed Density sitting on top of it.
I bought a new prom from the dealer for a 90-92 305 5 speed TPI car.
I need to disable the VATS and EGR.
Also, my car has the speedo wired from the tranny to the VSS buffer then to the speedo in the cluster. I am not running the VSS throught the ECM harness.
Will I need to disable the VSS in the prom programming?
I finally received my Pocket Programmer2 and my blank proms, 2 29 series eeproms and 2 27 series eproms.
Where can I find an ECU file for winbin so that I know that I am modifying the correct info.
This is my first attempt at a TPI swap AND at programming chips.
I have read a lot of the articles for DIY_ECM and programming
Any and all help is appreciated.
Thanks,
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Oct 11, 2001 | 04:31 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'm guessing, but if you have a 90 speed density, you need the 730 or 7730 ecu file. Whichever ECU file has the last 3 or 4 numbers of the ECM part number in it.
Winbin should come with it, if not, I'll mail it to you.
'92 Astro, GM crate 350 Performer TBI intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
Old Oct 12, 2001 | 11:18 PM
Zepher's Avatar
<font face="Verdana, Arial" size="2">Originally posted by V8Astro Captain:
</font>
I did aquire a copy of a 730 ECU. I wasn't sure if there were different ECU files for the different size of motor and transmissions.
Mike Davis emailed me and told me that the one I got from him should work.
Thanks,
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
customblackbird
Oct 1, 2015 04:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
