89 RS Transmission Mount Issue
Old Apr 4, 2018 | 11:12 AM
krismarsel1's Avatar
Engine: 2.8
Hey Guys. I’m having trouble finding a aftermarket 2.8 Camaro 1989 RS manual transmission mount.
The local shop tells me it’s circular , but everyone that comes up is a rectangle.
Do you guys have any experience with this? I don’t want to spend an arm and a leg for them to fabricate me something that would work.
Old Apr 6, 2018 | 10:46 AM
454 RS's Avatar
Car: 1988 Camaro RS
Engine: V8
Transmission: T5 NWC/700r4
Axle/Gears: 4th Gen 10bolt
Ive seen 2 different types of tranny mounts on 3rd gens usually v6 have the 2 piece crossmember with round bushings.
Old Apr 6, 2018 | 12:56 PM
Drew's Avatar
Re: 89 RS Transmission Mount Issue
There are three crossmembers. The one piece with the typical mount, the two piece crossmember with the typical mount, then there's a one piece crossmember with the fluid filled mount. The easiest solution for both of the oddball crossmembers is to get the typical one piece crossmember and typical mount.
Old Apr 6, 2018 | 08:18 PM
NoEmissions84TA's Avatar
I have the Energy Suspension POLY ROUND mount (1 box), don't know if 1 or 2 are required. Had it for 20+ years NEVER OPENED. I would hope the 1 box contains both pieces to do 1 crossmember. I will verify tonight.
Edit: I do have Energy Suspension p/n 3.1109G (black).
http://www.energysuspensionparts.com/3.1109
Old Apr 8, 2018 | 07:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some general info that may be useful:
https://www.thirdgen.org/forums/hist...ss-member.html
JamesC
Old Apr 25, 2018 | 12:29 AM
Engine: 2.8
Problem solved! Went to Hawks Auto and bought a v8 cross member , and a transmission mount from rock auto. Very easy install as well !
thanks
Hick_101
Nov 28, 2016 08:53 PM
Recaro T/A
Sep 17, 2013 10:55 PM
burdt
Jun 10, 2010 10:48 PM
breathment
Nov 28, 2001 06:17 PM
91banditt2
May 29, 2001 08:45 PM
