GM take-off torsen unit
Old Jan 5, 2002 | 04:10 PM
JPrevost's Avatar
Car: 91 Red Sled
I had this installed over the summer with my 3.73 gears. Long story short, why is it when I turn my one wheel one way, the other goes the opposite like an open diff? I know for a fact that I have 2 wheels spinning, trust me, I don't think I have to explain how I know. Is this normal for a torsen unit or is something broken?
Old Jan 5, 2002 | 09:43 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Its normal, Jon.
You have what is referred to as a 'torque sensing' differential. The Torsen has a pair of worm gears that couple the spider gears together. When the pinion applies torque to the ring, the torque is transferred to both axles. It is very hard to transfer torque to only one axle, as the torque is divided between the two worm gears. However, if you apply torque to a WHEEL instead of the ring gear, the torque is transferred easily to the other wheel.
AN interesting note: The percentage of torque applied to the non-slipping wheel is a multiple of the torque applied to the slipping wheel. Thus, if you raise a slipping wheel in the air, there is virtually no torque being applied to the wheel: It just free-wheels. Since the non-slipping wheel gets a multiple of this torque, the multiple of zero equals zero. Your car wont move, it'll only spin the airborne wheel...until it starts to grab a little traction, that is!
Old Jan 6, 2002 | 08:53 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Re: GM take-off torsen unit
I'm sure you found out by research in the local library
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
