4l60e only goes in low
Old May 3, 2018 | 05:49 PM
Lgray's Avatar
4L60E Connect and Cruse
Quick history
Trans worked fine, was having trouble with speedo after checking wiring found I was hooked into the speed out for the tach in wiring harness. found vss wire and disconnect the speed out wire. now the trans wont shift out of low. Does the speed out wire have to be connected?
Old May 3, 2018 | 08:28 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: 4l60e only goes in low
What do you have this in?
Old May 3, 2018 | 09:00 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
If he's the same Lgray on other forums he has a 2011 silverado
Old May 4, 2018 | 08:16 AM
Lgray's Avatar
32 Ford Dearborn Roadster
Old May 4, 2018 | 08:55 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Well I can tell you that in my truck, 4L60E, if I remember when i was having issues with the VSS that i couldn't get out of 1st.
It seems like with the 700R4 though if the VSS is disconnected, the speedo just doesnt work.
thunder85
May 1, 2017 03:00 AM
irocbrninrubber
LSX and LTX Parts
Mar 15, 2017 03:57 PM
3rdgenlsx
Jan 7, 2017 10:01 PM
Cadride
Oct 25, 2013 05:16 PM
Fast355
Mar 2, 2011 09:54 PM
