4th Gen pedals in a 3rd Gen
Old Sep 4, 2018 | 07:39 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Almost have all my parts gathered for my T56 swap in my '88 L98 IROC.
One quick question. I'm replacing the thirdgen brake/clutch pedal assembly, and using a 4th gen setup...I know it fits, but what about the switchgear on the 4th gen pedals? Are they plug and play in my '88, or do I need to either rewire under the dash, or use the switchgear from my old 3rd gen pedals?
Old Sep 5, 2018 | 01:13 AM
Drew's Avatar
Re: 4th Gen pedals in a 3rd Gen
The 4th gen switches won't plug right in. Either use the thirdgen switches or rewire. The only switch that is the same will be the neutral safety switch.
Old Sep 5, 2018 | 10:33 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The retainer for the 3rd and 4th gen brake light switch should be the same size. You should be able to pull the brake light switch out of the 3rd gen automatic pedal assembly and put it right into the 4th gen pedal location.
Old Sep 5, 2018 | 11:36 AM
Car: 1988 IROC-Z
That’s exactly the sort of stuff I needed to know. Thanks!
AutoX86Z28
Nov 16, 2004 06:18 PM
19WS6T/A91
Feb 2, 2003 11:14 AM
FiReBReTHa
Dec 9, 2001 01:12 AM
