Death wobble past 65mph and letting out clutch
Old Sep 25, 2018 | 07:53 AM
Claydoh15's Avatar
Car: 1991 Formula Firebird
Engine: Carbureted 350
Transmission: World star t5
Axle/Gears: 4:10
Have a 91 firebird with a t5. Backstory last motor was knocking but had no other real problems. Put a new sbc in it but with a carb of course. Car has been doing fine for about a month now. Last weekend I drove 250 miles home, had a slight vibration so replaced U joints on both ends of driveshaft with moog. Broke them in by doing donuts in a field. Went on a drive and had a death wobble starting at 65mph and getting worse at higher speeds. Thought the moog u joints were junk so popped them out and replaced them with spicer. Still wobbles. It’s more of a violent vibration. It’s most noticeable holding the shifter. Gets worse with more speed. Can’t figure out for the life of me what it is. When it starts shaking you can hold the clutch in and put it in neutral and it still shakes until you slow down. Car also shakes letting the clutch out into first gear and reverse
Old Sep 25, 2018 | 09:38 AM
big gear head's Avatar
Re: Death wobble past 65mph and letting out clutch
You might have bent the ears on the drive shaft yoke when you were pressing the u joints in or out. I've done that before.
Old Sep 26, 2018 | 06:12 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Check your tires for a bubble. Maybe the doughnuts damaged the rear tires.
Old Oct 2, 2018 | 05:00 PM
Roblaza's Avatar
My bet is on a damaged drive shaft. Bent ears, weight fell off in the process of changing the joints...has the ride height of the vehicle changed at all? How is the the slip yoke moving on the output shaft? If that's sticking it'll cause vibes too
bbsr72
Oct 31, 2013 09:31 PM
Dante93GTZ
Jan 3, 2012 02:27 PM
87350IROC
Oct 9, 2011 05:10 PM
kallark
Aug 16, 2010 04:18 PM
Jim85IROC
Apr 27, 2002 06:36 PM
