Pictures of cracks at the steering box... Death wobble...
Old Mar 30, 2011 | 07:59 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Anyone have any pics of their cars with the cracks at the steering box; You know, the one that causes the death wobble?
I want to ensure I look everywhere on my 91 Z28 when I get it on the lift next week....
Anyone got any pics of the before and the after?
Old Mar 30, 2011 | 09:04 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Re: Pictures of cracks at the steering box... Death wobble...
Kind of hard to tell here, I only have a couple of pictures about like this. If you look close you can see there the lower rear steering box mount was half *** "repaired" by a previous owner. They tried to weld over a crack with everything installed.
The cracks were on all of the mounting points though. I had to grind everything clean and I just started welding away. Because of the wobbling, the holes through the frame rail wore out of round. I just tacked the washers down on the outside to fix that.
IMG_0764.jpg?t=1301536403
Old Apr 5, 2011 | 08:18 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I assume the steering box has to come out to do the fix?
I'm just trying to figure out how to get it prepped for a shop to weld it up as I don't weld. I'm guess I'd have to trailer it somewhere to have the work done...
Old Apr 5, 2011 | 08:37 AM
2600-watt-rs's Avatar
Car: 1991 Camaro RS
Engine: Transplant 350, Building 355
Axle/Gears: Stock
Is the death wobble only when you hit the breaks? I got a major death wobble but only seems to happen when it wants to as i hit the breaks hard.
Old Apr 5, 2011 | 08:47 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
That sounds vaguley like you have worped rotors. Death wobble you should feel at speed as well.
Old Apr 5, 2011 | 10:18 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I noticed the problem when going 40-45mph and hitting a pot hole - The car shook so violently I thought a wheel was coming off... As soon as I slowed down, it went back to normal - Hasn't happened since, but then again, I've been really careful around potholes!
Old Apr 5, 2011 | 10:23 AM
Car: 1991 Camaro RS
Axle/Gears: Stock
Lol it is definitely a "depends" moment...
Old Apr 5, 2011 | 01:25 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Old Jan 3, 2012 | 02:27 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
That's exactly what mine is doing. Whole I'm braking, if I hit any kind of unevenness in the road it causes my car to lurch and buck until I come to almost a complete stop. Pretty scary.
I'm assuming this is the famous crack in the frame, as it feels just like my old third gen that had the same problem. I never got it fixed though, but I need to get this one fixed. I don't have welding equipment, so should any decent garage be able to handle fixing it?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
chubsworth
Aug 26, 2015 02:34 AM
