v6 t5
Old Jan 31, 2019 | 11:22 AM
230 firebird's Avatar
Car: 1987 pontiac firebird
Engine: sbc 350
Transmission: TKO 600 5 speed
Axle/Gears: 323 posi/disc from 86 gta
v6 t5
Hey guys and gals.I need some advice.!st off,sorry if this is not posted in the right place or way.Here is my question.I have a 2.8 in my 87 Firebird.I am going to purchase a rebuilt T.P.I sbc350 said to have 350hp.I want to know if I can use my t-5 and buy new clutch,flywheel,ect.If not I am trying to decide on a used T-56 or a new Tremic TKO 500.I have read the post where some say the t-5 will not last and others say they have high hp and still use a t-5.Any,all advice is appreciated.
Old Jan 31, 2019 | 12:00 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: v6 t5
You can use it but the gear ratios are designed for a V6 so they will be very short. It is also not that strong but can last if treated right.
Old Jan 31, 2019 | 03:18 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: v6 t5
I have a V6 T5 behind my L98.
Definitely poor gearing, particularly 1st, at 4.03. I'm shifting into 2nd before I even clear most intersections...part of the reason I have a T56 rebuilt, ready for me to install.
Old Feb 1, 2019 | 08:06 AM
Re: v6 t5
What they all said:
You will not like it. And, it's the weeeeekest T-5 setup there is, which means, it'll be just that much more likely to fail in a very short time.
You can hack it together that way with a V8 bell housing and a 4.3 clutch disc, but start hunting down a T-56 swap.
