What T-56 cross member and Torque Arm do you recommend
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Lost 3rd gear in the T-5 today. Picked up a 97 T-56 a while back. Looking for recommendations for cross member and torque arm? What do you guys recommend?
Re: What T-56 cross member and Torque Arm do you recommend
I have the Spohn one. Not perfect IMO, but within a range I can work with. Once I overcame its inherent limitations, it worked quite well.
Limitations included, the fact that the trans mount pad on the Xmember was located WAAAAAAYYYYY to the rear of the place that the Xmember bolts to the "frame" (unavoidable... the trans is simply longer, which can't be changed) which puts torque on the Xmember, trying to twist it off of the "frame"; and that the giant bolt going through the upper bushing, was too close to the transmission, which made it come REAL close to hitting the trans; and that the bolt was not a tight fit in the bushing, which allowed the whole thing to shift, leading to the "clunk" you may have heard about. Each of those things required a little ingenuity but once they were vanquished, it works QUITE well.
Car: '89 Firebird
Engine: 7.0L
I think Holley has the best design these days for a trans crossmember with integrated torque arm mount.
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
IROCZ28KevinZ
Jan 6, 2009 07:41 PM
ndamron
Mid-West Region
Dec 28, 2006 02:53 PM
ndamron
Dec 18, 2006 05:59 PM
downwithET
Aug 22, 2002 01:42 AM
