difference in regular t5 cross member to t56 cross member?
Old Aug 21, 2002 | 08:15 PM
downwithET's Avatar
can either be modified to work? how are they different? thanks
Old Aug 21, 2002 | 08:25 PM
87RS402's Avatar
best advice....pay the $100.
There are instructions on the net that tell you how to make the T-5 crossmember work but send Spohn the $100, you'll be happier and have a stronger part.
Old Aug 21, 2002 | 08:34 PM
downwithET's Avatar
NO!
Spohn is good yes, but i have a welder and a torch and every tool i will ever need and I can make anything Spohn can. I wanted to know the difference in the cross members. Thanks for your reply though 87RS402.
Old Aug 22, 2002 | 01:42 AM
PIMPINPHIL's Avatar
hi,
someone correct me if im wrong,but im pretty sure,that you need to cut your crossmember at the parts where they bolt on,like .5 inch,or so b4 that spot,and then weld up a piece of steel backwards,and then reweld the center section to the backwards one,basically just moving the center section back a few inches to line up with the t-56,i really dont know measurements,but i know you can make it work.
grngryoutmyway
Oct 18, 2016 05:48 PM
PurelyPMD
May 5, 2016 04:57 PM
tattmann
Sep 27, 2015 05:20 PM
luvofjah
Sep 26, 2015 08:28 PM
Numbah-1
Sep 12, 2015 08:57 PM
