Moser 9" torque arm bracket no lining up
Old Apr 6, 2019 | 03:09 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
So I'm getting everything mounted and set up and run into a problem, I started to bolt up the torque arm bracket from Moser and only 2 out of the 3 bolts line up. I noticed when I was starting to thread the bottom left bolt in and noticed it started to get a good amount of resistance, Looks like it started to cross thread the first couple threads so i'm going to chase the threads, has anyone run into this situation before ? I guessing they use a jig to weld the 3 pieces of round bar on the housing so i dont know how its out of wack, it sits up enough and slightly to the right when the bracket is on that the the top of the threads are pushed up a couple two three 16ths
Old Apr 6, 2019 | 07:48 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Moser 9" torque arm bracket no lining up
did u start all 3 first ? mine went it no problem just chase the threads first make sure theres no debris in there
Old Apr 6, 2019 | 09:54 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Chase it from the opposite side of the hole if you can to avoid cross threading the the chase tap. I don't recall having any issues with the Moser torque arm bracket on mine when I got it. I have a Spohn torque arm and the instructions with the Spohn product advised me to grind away the center section ribs if there was a clearance problem. This is so that their one size doesn't fit anything junk could work. I did the opposite and removed quite a bit of the Spohn mounting bracket instead.
Old Apr 7, 2019 | 06:10 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I started top first and left it loose the moved on to the bottom 2
Old Apr 7, 2019 | 06:12 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Good idea, I'm just going to have to find the size of the bolt / threads so I can buy a tap
Old Apr 7, 2019 | 12:11 PM
91ls1t56's Avatar
Car: 91 Z28
From what I remember that is a pretty big bolt and that threaded tube is quite long. You may have to get creative to get the tap long enough to get all the way through from the opposite side.
Old Apr 10, 2019 | 04:42 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Got the tap in and cleaned up the threads, torque arm bracket is still off and I dont have the time or patience to screw with it. Threw it up on craigslist last night, it can be someone else's head ache
Old Apr 10, 2019 | 06:25 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Link?
Old Apr 10, 2019 | 06:27 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Is it possible the mount was bent during shipping? Is this something that could be "fixed" with a 5lb hammer? I only ask because when I received mine years ago, the housing end was bent from being dropped off a truck somewhere during transit. I worked it back and honed the bearing bore and all was well.
Still sucks either way
Old Apr 10, 2019 | 06:43 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Mine was like that but don't think as bad. I just drilled the bracket holes out to the next size. Been in the car for over 20 yrs now.
Old Apr 10, 2019 | 06:55 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Its either from the jig being off or in transit from shipping, they only put the housing in a card board box and it over 100 lbs and ups did me no favors either. I started hitting the mounts with a hammer, they moved slightly but in the process it's taking a toll on the metal dents, dings and gouges. Something I really can't stand since I dropped so much money on this rear end and brake package
Old Apr 10, 2019 | 06:58 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I was thinking about that too but didn't know if any slop in the bracket what have an adverse effect on the rear end or torque arm during load. Last thing I want is it shifting or coming loose screwing up the pinion angle among other things
Old Apr 10, 2019 | 07:02 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
It's bad enough when started putting the center in that the studs that were supplied with the housing from moser started to strip torquing the center down to only 35 ft lbs. I had to knock out all the studs and buy Arp studs and re install everything
Old Apr 10, 2019 | 07:22 AM
TTOP350's Avatar
I've never seen any witness marks from movement esp with the tq I put on them. Back in the day the car went mid 1.5 60fts. I used factory ford studs nylon lock nuts for my 3rdmember.
Savage388
Apr 28, 2013 02:37 PM
ls1>*
Apr 22, 2013 12:02 PM
turbopezz
Jun 8, 2009 08:50 PM
Pablo
Jun 1, 2004 11:08 PM
